Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 06-29-2006, 07:05 AM
tgh99si tgh99si is offline
headlight swap
hello i was reading the thread below but it didnt quite answer my question. i have a 99 f-350, and i got the amber corner lenses with the crappy headlights (the two piece stuff). anyways, i was wondering do the headlights that came on the 02+ (the clear one piece ones) do they swap right in, wiring, and all that? thank you guys.
Old 06-29-2006, 07:31 AM
dragr8cer dragr8cer is offline
I was actually wondering the same thing, as my case is the same. Any answers???
Old 06-29-2006, 10:29 AM
gcop gcop is offline
PIPE HITTER
I think they are the same up to '04.
Old 06-29-2006, 01:50 PM
SuperDuty1 SuperDuty1 is offline
Yes they will fit. All the wiring is the same. I put the 02 headlights and turn signals in my truck, everything went right back into the same place. Just use care when removing old headlights, the header panel is made out of fiberglass. It will take a little persuasion to get the old one out. But worth the effort
Old 08-07-2006, 07:42 AM
7.3dofbft 7.3dofbft is offline
I think you can put up to 05 headlights in a 99-03 truck if I am correct, saw a guy with an 02 that had the black harley davidson lights in his, and he was going to do an 05 front conversion, but doing the front bumper and grill upgrade along with those headlights.
Old 08-11-2006, 09:56 AM
NCHornet NCHornet is online now
Powerstroke Techie
99-03 are a direct replacement. I installed the 02 headlights and corner lights on my 2000 and they look awesome and the light output is awesome, I also have the heavy duty harness from Gosracing.com. see gallery for pics.The o2 and 03 user a different adjuster on the top outside corner so make sure if you buy them off ebay you get the adjusters with them. I also have the 05 grill on my truck.
The 05,06 headlights are not a direct swap, the header panel has to be modified to allow these to fit. Some of the vendors of the TDS forum sell a complete of conversion kit, for about a grand, you get the headlights, header panel, bumper and grill.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
