LineX or Rhino Linings? for rockers???? - Ford Powerstroke Diesel Forum
Old 09-10-2007, 04:40 PM
I am fixing up the rock chips and a little rust at the bottom of my white 2001
F250 supercab 7.3 shortie and thinking about useing the spray on liner for the rocker panels. Any Pros/cons? thanks.
Old 09-10-2007, 05:01 PM
International Threat
I used to spray permatech - they're all about the same - key is preparation.
Can't really go wrong with either.
Old 09-10-2007, 05:09 PM
DKR DKR is offline
<--Pro Cooler Racer
I have Rhino Linings. Now, the Line-X I've seen doesn't appear to be as a thick of a coating. Probably just as tough, but I don't think it provides as well of "shock" protection if you drop or bump something.
Old 09-10-2007, 05:15 PM
I have the LineX in the bed of my truck and i love it. My buddy has the rhino lining and it's wearing out! I'm sure it had to be how it was done though cuz i've seen others that are in perfect shape. The LineX was a little cheaper when i did it, and they did it a little different than Rhino would. They took the bed bolts out and sprayed, and then put them back in and covered them too to make sure it seals real tight, where Rhino doesn't cover them. The only downside i see to that is if you ever need to take the bed off... My truck doesn't get beat up, but i'm not afraid to throw something in the back either...
Old 09-10-2007, 05:21 PM
If you need to take the bed off just use 2" a hole saw and you can go through the bed liner around the bed bolts. After that peel it off... it isn't that hard.
I once had to peel off an entire bed worth of bedliner because our chemicals eff'd up. Took 2 days LOL to get it all off.
Old 09-10-2007, 05:30 PM
OUCH!! Good call with the hole saw. I never thought of that...
Old 09-10-2007, 05:34 PM
I've had a rhino liner and it was ok, i hauled alot of stuff and it faded pretty quick, then it peeled in two places and they weren't real thrilled about honering their life time guarentee. But I guess it's all a matter of personal oppinion.
Old 09-10-2007, 05:43 PM
Thanks for the input, Still hard to choose. I wish there was a difference that would make it easy to choose. Someone told me today that lineX would be better because it has less of a texture then Rhino and would look better...
I dont think the rhino in the pic looks bad at all, what do you think of that color grey on a white truck?
Old 09-10-2007, 06:33 PM
I did my own with the spray on bedliner stuff in a rattle can from carquest. Turned out really good. Only problem was I only properly prepped one side, and now the other said is flaking off.
Old 09-10-2007, 06:48 PM
both are very good.... but the military is in the process of using Linex around bunkers for blast protection..... just a thought
