| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
my 05-07 HD headlamp conversion
Got the lights in the mail last night
. I start the conversion today! I'll post my progress.![]()
Done!!!
Here are some photos of my progress. Prep, all needed tools for job. ![]() ![]() Before ![]() Aftermarket lamp seals are iffy, takes about 5 min to run some silicon on both lamps. I used flowable to be sure it gets in the gaps. ![]() ![]() ![]() removed lamps and signals, required a bent awl to take the back clips out (2) per side. ![]() ![]() Cut/grind. I ended up using my grinder 4", sawzall, and my dremel. Took my time trimming,fitting,trimming,grinding, grinding,fitting so on and so on. ![]() ![]() ![]() ![]() ![]() One side is done (had to remove grille to properly execute cuts and trims) ![]() ![]() Same for other side (getting closer and trying not to rush) To mount top I used 4 cage u nuts, 4 locking washers and 1/4" fine threaded bolts (4), 2 per side. Also, it did require a couple small drills on top of the header panel to fit the top mounts properly. ![]() ![]() All Done!! ![]() ![]()
FYI.
I was able to adjust my new HD's (up and down) with a 4mm socket. Fits like a glove. |
looks good
Looks awesome! Where did you get them?
Thanks guys, here is the link from ebay:
99-04 SUPERDUTY EXCURSION CONVERSION 07 HARLEY HEADLAMPS HEADLIGHTS 00 01 02 03 | eBay |
Looks good!
Thank you. I received a couple compliments around town as well!
nice install turned out great.....now you just need to step up to a set of HIDs (i love mine)
looks good man
