New bumper - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-23-2011, 08:26 PM Thread Starter
New bumper
LOL I always thought I was gonna get a Road Armor bumper for my truck. I picked up this new bumper for $300 from a guy locally. What cured me from getting a Road Armor is my buddy got one for his 05 f250 and man that thing is LIGHT not to mention that there are only provisions to put two bolts on either side to secure the bumper to the frame. I thought it was completely crappy design as far as the mounting system. And the rear bumper brackets jesus talk about made form taffy. I think we use thicker sheet metal on the terminal cabinet doors at work.
I looked at my rear bumper and I am just gonna make my own. Ill post pics when I get it done
So what do you guys think of this front bumper. I have a 12K warn inside the winch area
Whats even funnier is it sits no lower than my stock bumper and when I took off the brush guard front winch mount and front hitch I realized how much better this looks than my last arrangement
Thanks for letting me show off my trucks bumper
Rob454 is offline
post #2 of 5 Old 10-23-2011, 08:37 PM
Maverick1701's Avatar
Send a message via AIM to Maverick1701
that thing looks pretty hefty! I approve!
ChrisChris
2003 Kawasaki KLR650
1997 Ford Expedition 4x4
1967 Kaiser Jeep M35A2 6x6
2016 Silverado 4x4 Crew-Cab LS/Police
Maverick1701 is offline
post #3 of 5 Old 10-23-2011, 08:42 PM Thread Starter
Thanks. Whats funny is i took measurements to see if it would sag a lot and I must have some stout front springs cause it only sagged less than 1/2 inch from the original measurement. But i already had a bunch of crap on the front at the time. So I really traded weight for weight but this is a lot stronger than my last set up which was this. The winch was on a removable mount and is not pictured.
Rob454 is offline
post #4 of 5 Old 10-24-2011, 07:11 AM
Freedombyforce's Avatar
I'm going though the same pains right now.
Iron Bull Questions/Problems
How many mounting places does that bumper have on it? I just don't think 4 bolts on a heavy bumper with a 12k winch in it is enough. I may make at least 2 more braces on the sides.
2002 F-250 CCSB
ZF-6 Swap
Manual T-Case Swap
K&N Intake, CCV Dumped, Riff Raff Boots
Foil Delete, AIH Delete, EBPV Delete
Wicked Wheel
Farm Boy's 5" Straight Pipe with 6" tip
PHP's Tunes with 6 pos
Hutched 51 gal Titan Tank
Iron Bull Bumper with PIAA 510's and Strobes
Warn M12000, Retrosolutions LED's inside and out
2011 Tailgate -Taillights - Front Ford Emblem
17" Fuel Octanes with ProComp Extreme AT 35's
Freedombyforce is offline
post #5 of 5 Old 10-24-2011, 07:40 AM Thread Starter
My bumper has 4 bolts per side. The frame horn plates and the bumper plates are identical so you can put 4 bolts per side unlike the factory bumper which takes two per side. Basically the mounting poiints are mirrored from frame to bumper so they utilize all 8 bolt holes. I used grade 8 bolts washers and nyloc nuts. My buddy has a Road Armor bumper and it only allows you to put two bolts per side. It's the way the mounting brackets are designed and not wide enough and he has the quad driving lamp holes and they interfere with the outside part of the factory frame horn mounting plate. the mounting bracket is 1/2-3/4 the width of the factory frame horn plates so you don't have a choice to use the outside holes on the frame. I guess if youmade your own mounting plates but whats the point. That shoudl be a done deal from the manufacturer.. Really cheezy design IMO. As for the steel its way thin. Its a little thicker than the factory bumpers. The angles and the way the bumper is built help but for the money IMO its more looks than function. iv'e seen Road Armor bumpers bend pretty easily when hit off road liek when my buddys landcruiser landed on a rock as he was putting the tire down. For the money you spend on those bumpers they need to be freaking bulletproof and they are not.
I looked at the link you provided and my buddy has the same problem with his Road Armor bumper. Radiator support bracket hanging down ( looks like s**t)and driving light buckets hit the frame horn and the idiotic two bolts per side, which I can understand from a factory bumper. its there for aesthetics, but a $1200-$1800 hell screw that 6-800 dollar bumper should have some STOUT mounting points. After wanting a Road Armor bumper for a long long time on all my trucks i can tell you its a HUGE disappointment to see the actual shoddy material used. The brackets are slightly thicker than the factory brackets. IMO those are bumpers that rely on the looks and name recognition to get sales. I wouldn't put one on my truck now if you gave it to me.
This was my front hitch. it uses 4 bolts per side. See the flat part where the mounting points are. Thats how the bumper mounting plates are. I did have to remove the front tow eyes cause they are useless now.
Rob454 is offline
