| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
Painted Grill
Has anyone paint their inside grill where its black plastic to match the color of the truck? IF they did do you have pictures and what paint should i use?
You can use bumper paint. Get it at your local auto parts dealer. Take time masking off anything you don't want painted and make sure you use primer...of a contrasting color that your going to paint. (If your painting it white for example, use black primer.) I made this mistake. I primed in black and painted black. It makes it really hard to see what you've painted.
I didn't paint the inserts. I painted the whole grill flat black and it looks AWESOME! Also make sure you clean the area to be painted REALLY good! |
Make sure your grille is really clean. I even took real fine sandpaper and made sure everything was smooth. Definitely prime the surface first. I used Rustoleum plastic primer. Then used regular spray paint.![]()
I did pretty much the same thing. Masked it off, sanded it down, cleaned it up and went to spraying.
Here is a little write up I did on mine. I did mine so I could put a billet grill in place and you would not beable to see the old stuff under the new. Turned out pretty nice if I do say so my self ![]() Bolt On Billet Grill Install |
Thanks Stump!! Was pretty easy.
I painter my grill, basically took it off the truck masked it off, scuffed all areas whereI wanted to paint, and then took my time painting it and made sure I had no runs or drips, and then re-installed it. Funny thing is, I get more complements about that painted grill than I can tell you, people really seem to notice it.
Mine came from the factory painted in there :-x
A rock hit it and screwed it up, so I got an ALL chrome grill... |
