| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
Leveling kit
I was looking around on eBay for leveling kits for my truck and saw these:
eBay Motors: FORD F-250 F-350 SUPERDUTY SUSPENSION LEVELING KIT 4WD (item 230142796001 end time Jun-20-07 10:55:14 PDT) I was wondering whether or not anyone has used modified shackles or if they're even safe. I was also wondering what size tires i can clear with just a leveling kit. I have 265/75/16's now, but when I get new tires i want to go to a 285 MT. I have the factory black plastic mud guards and I hope i can clear those without rubbing. Any help or advice is greatly appreciated. David |
-Raul |
I think Joe (stump0331) has some on his truck. You might want to PM him and see.
just wanted to let yall know that the 285 and 315 is just the wideth. those metric tires r stupid on how they measure them. the first number s the width and the second number is the height( its actually the percentage of the width for the sidewall) then the wheel diameter.
i think its a stupid way of measurin a tire, i likt he old 35x14x15 measurment system myself. just wanted to put that out there for yall, most people dont know how metric tires r measured. its a common misconseption |
take a 315/70/17 for example, 315 mm wide, 70 % of 315mm is the sidewall height, then 17" rim
Thats pretty cheap for a leveling kit, and sounds pretty easy to install. Hope somebody has some feedback on how they compare to other leveling kits.
Ok, thanks for the opinions guys. I'm still not sure though if the hangers are a good way to go. What's the general opinion on add-a-leafs? I've always thought that was the way to go.
in my personal opinion i found the shackle lift easier to install than an add a leaf... plus the ride quality will stay like stock cause your only adding some longer shackle... with an add a leaf it will get a lil stiffer because of the extra leaf.... good luck and let us know if you have any other question
-Raul |
Well, I like the sound of keeping my stock ride. And I'm assuming hangers won't cause any alignment problems down the road. What kind of price can I expect for some good hangers? I just want to level it, so I'm thinking 1.5" or 2"?
Should be able to run 285's no problem without any modification. I have 285 BF Goodrich's on my stock ride with no issues. I don't have mud guards, however.
