| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
lift question
i have a 6.5 inch pro comp lift on my 2000 f-250 and i wanna put a couple more inches so i can fit 38's on it, any suggestions or does anyone know anything out there that will lift it some more, i dont wanna take it off and get a new lift and i dont wanna put body lift on it if i dont have to.
i have a 6" bds on 37's i ordered a 2.5" spring hanger kit from rubicon express for $275 . should clear 38's
Is there an issue with the front driveshaft and breaklines when going from 6.5 to 8" lift?
You could buy the Sky Jacker 8 inch lift and sell your 6.5" lift.
Skyjackers ride is to stiff ..IMO
if you want to add a few inches a hanger and shackle kit is going to be the best option. things that need to be addressed. Shocks will need to be longer. in front track bar may need to be replaced to a adjustable one. front driveshaft will need lengthining,a as pacer or a longer slip joint. brake lines ....lengthened.. or corrected rear will need to be raised rear shocks will need to be longer. more shims added to carrier bearing drop if equipped rear break line needs lengthing body lift is not a option on a Diesel unless you customize a kit. |
