| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
99 dash
ok so ive been tryin to figure it out but i cant. how does the upper dash come off?? thanks
are you talking about the piece around the instrument cluster and radio?
yes that part
Just pulls out. You will need to remove the radio first.
no bolts or anything?
Just some clips. It can be a bit tight, but just work your way around the edges and it will come right off.
ok start on the driver side. Pull it out a bit, then reach your hand back and pop the headlight switch out. Then work your way around the steering wheel. Then pop the 4x4 switch out of the dash. When I got around the radio, you can either use the tool to pull the radio, or pull the dash out around it and reach in from the back and pop it out. Just make sure to unplug the cig lighter, 4x4 switch and whatever else there maybe. It is pretty easy to do.
thanks for the help
