3rd brake light leak? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-03-2010, 04:42 PM Thread Starter
OregonStroker's Avatar
I seem to have a leak along the passenger side of my crew cab, it goes all the way along the passenger side. For the longest time I thought it was the windshield but couldnt find water under the dash on the firewall anywhere- just dry dust. I did more online research and found out that a lot of f150 guys have problems with the 3rd brake light seal? Sure enough I pulled the interior pannel back behind the rear seat and there is water way up in the back corner under the speaker.
So- for any of you who cant figure out where your leak is coming from- chances are it is the 3rd brake light.
Built engine, rods, pushrods, cam, springs. Meth, turbo, injectors, fuel system, oil system. 3 disk billet, billet shafts built trans, 6.0 IC, exhaust, intake. Latter bars, gears, system, tint, HIDs. You know the typical stuff to make a 7.3 get out of its own way...
dont brake.
OregonStroker is offline
post #2 of 3 Old 04-03-2010, 08:40 PM
Yep,I've heard of that a few good times,seems like a problem that we are all going to need to look for in the future .
Thanks for the helpful warning!
icysmooth is offline
post #3 of 3 Old 04-03-2010, 09:01 PM
PahStroke's Avatar
i took mine off to put smoke wrap on it and when i washed it it leaked, so i siliconed it
03 F-350 Lariat 7.3 TW Chip, Diamond Eye 4", DIY Intake, CFM Plus, zoodad, unhooked waste gate, D.I. x-over, Auto Meter Ultra Lites, Dash Pod
PahStroke is offline
