Factory 20"s on my '01 - Ford Powerstroke Diesel Forum
Old 03-28-2010, 08:37 AM
THinking of upgrading to better wheels on my '01. There seem to be a lot of factory 20"s from 05-current trucks....will these just bolt up or do I need spacers? Anyone done this?
Also, I have 2wd....will I need a front end lift?
Lets see some Pics!
Old 03-29-2010, 08:26 AM
Nobody.....?
Old 03-29-2010, 06:22 PM
im new here, but from what i read, you must use spacers and the only ones worth buying are made by a guy on here, they are hubcentric, where ebay spacers are not. they are like $600 for the spacers alone
Old 03-29-2010, 06:25 PM
Send a message via AIM to dsljnky
I believe the bolt patterns are different> if your goin to get a spacer anyways you could just get an adapter
Old 03-30-2010, 06:32 PM
IBEW Journeyman Lineman
Just from my experience, no the bolt pattern isn't different but the offset is. I had a set of 17"s off my 05 that a guy wanted to buy and put on his 01. they bolted up just fine but the rims rubbed, I think it was either the steering linkage or caliper, don't remember exactly. The 05 rims didn't stick out as far and gave the 01 a more narrow stance. So that would be what the spacers are for. The 20s shouldn't have that clearance problem since it was just a slight rub on the 17s. I'm not sure about them being put on a 2wd though if there would be any issues on the front end height there.
Old 03-30-2010, 07:47 PM
Kapoweeee! look at my sig...
no spacers needed..tires rub..want tires not to rub? space them LOL bolt patterns the same, reason for the offest being diff is the newer diffs are 3" wider then ours now..
OH you cannot use the 05 caps unless you have spacers, will need to use your originals!
Old 04-06-2010, 06:08 PM
im not 100% sure on 2wd trucks but i know on 4x4 trucks the 05 and newer wheels rub on the leafs because of the offset, and that was the year they switched to coils in the front.
Old 04-06-2010, 08:24 PM
haha read my post above..they rub,, unless spacers installed...
