air compressor and mounting location... - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-27-2010, 07:14 PM Thread Starter
Im looking at getting an air compressor to run an airhorn i want to put on my truck, also i want to run some air tools like an impact gun, air ratchet, and fill tires and such if i need to.
I was looking at the viair compressors, unless theres anything better? also i have a 2002 f-250 4 door short box, where would be the best mounting place for a 2.5 gallon tank? (i was thinking the toolbox, but id like to keep the space for tools. Any opinions? thank you.
IVIuzzy is offline
post #2 of 15 Old 03-27-2010, 07:22 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I think Viair's are the best. I think, not sure though. Personally, I'd like mine under the truck because I have stuff in the toll box. As in full.
If you wanna run stuff like that get a compressor that has a 100% duty cycle
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 15 Old 03-27-2010, 07:25 PM Thread Starter
its difficult to see the dimensions online, so i dont know where under the truck itd fit easily, im sure that they have it in mind being that theyre 12 volt, so im sure it can run along the frame rail under the cab? i just wanted to know if anyone here has installed one to see where they put it to find my options.
my friend put his where his spare tire goes, but then im SOL without a spare.
IVIuzzy is offline
post #4 of 15 Old 03-27-2010, 07:27 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Yea my spare would stay on. I'd think somewhere along the frame rail. Maybe on the passenger side where there's not much stuff.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 15 Old 03-27-2010, 07:36 PM
azkcr's Avatar
Quoted: 3 Post(s)
I put mine on the frame on the passenger side. Tucked in there nicely underneath the bed.. I could try to get a pic for you when I go home thursday if you wanna wait the long
Ben Conner
LSP Assistant Director
Got every PSD made...
My DD: '13 6.7L with Optimus Prime's wanker still on the exhaust
azkcr is offline
post #6 of 15 Old 03-28-2010, 06:07 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
I put it all on the passenger side. Compressor is in a box I made, bolted to the frame rail on the left (Viair38C), Horns bracketed from the bed, Tank bolted & strapped. The drivers side has all those parking brake cables...
http://www.powerstroke.org/forum/att...1&d=1269785138
NoRalPh is offline
post #7 of 15 Old 03-28-2010, 06:25 AM
The compressor i have for my airbags isnt all that big but i did the same, mounting inside the frame rail on the passenger side about halfway back
2012 F350
ross3031 is offline
post #8 of 15 Old 03-28-2010, 07:34 AM
jesilvas's Avatar
Quoted: 3 Post(s)
VIAIR Corporation - 330C IG
That's the smallest compressor Viair has with a 100% duty cycle.
And there's the big boy
VIAIR Corporation - 497C
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 15 Old 03-28-2010, 09:04 AM
azkcr's Avatar
Quoted: 3 Post(s)
Good stuff.. I'm needing a new one
Ben Conner
azkcr is offline
post #10 of 15 Old 03-28-2010, 09:54 AM
CSIPSD's Avatar
Put it in the tool box. There is no reason to subject the compressor to all that abuse.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
