Stock rims - Ford Powerstroke Diesel Forum
Old 03-01-2010, 04:22 PM
Stock rims
I am away from home but i was wondering the width of my stock 16" rims? its on a 2002. I want to go with a 38x15.50r16 but was hoping to use them while finding another rim. Whats your thoughts?
Old 03-01-2010, 04:50 PM
You'll want to run at least a 10" wheel for a 15.50 cross section. My 315/75R16s (12.50 cross section) balloon quite a bit on the stock wheels. I think the stock wheels are around 8 inches wide. Not sure as I'm away from home too.
I checked the spec page at Toyo tire's site and they give recommended wheel widths for each tire.
Old 03-01-2010, 05:11 PM
yeah my after markets are 17x8 and i like my 35x12.50s. a friend wants to buy my tires from me but i want to go to a 38 but dont want to have to buy the rims right now. is there anyway i could run 1550s on them until i bought new rims?
Old 03-01-2010, 05:33 PM
Assuming you could find someone to mount them like that, you might get away with it for a while, but...
I personally wouldn't do it. Tire wear would be one issue. Having the sidewall severely bowed in and affecting the angle of the tires bead to the lip of the wheel could be another issue. The manufacturers have pretty good reasons for their recommendations. Your life depends on it!
Old 03-01-2010, 05:59 PM
There is no way in hell that tire will fit on a stock rim. Stock rim is like 7.5" wide. Largest recommended size for that width is going to be a 285/75/16. Any wider, and you'll get the ballooning problems like seawolf is having. That means the centers of your $1000+ of tires wear out really fast.
Old 03-02-2010, 07:05 AM
My 02 lariat has 16x7 wheels. The recommendation I have been given is no larger then 265/75/16 but 285/75 might be ok tire depending. Hope that helps.
Old 03-05-2010, 08:15 PM
I wouldn't do it either,tread wear depending on weight rating of tire will differ,but picture this-a fat person on a 2 inch wide see-saw,I know this because I've been there-good chance is they're gonna fall off when loads get heavy-or unsuspected shifts-not safe!
Save your money and match your tires to rims per manufacture's specs,these trucks are heavy-between 6,000 to 7,500 lbs dry weight depending on cab/bed combos
Don't risk the safety of yourself or others just to make the rig look cool,I've seen tires roll off rims and cause severe/fatal accidents,just be wise with what you choose-we don't want to see a thread from you about any bad luck - Hope this helps!
