Question about dual shock kit - Ford Powerstroke Diesel Forum
Old 02-25-2010, 05:12 AM
Well I am about to order a dual shock kit. I have a 6 inch lift on the truck and the guy I bought it from just put new regular shocks on it.
I am wondering if it is possible to get the rough country dual shock mount and run a better shock and leave the other one still on there. Like one MX 2.0 shock and the one shock that is already on there.
Old 02-25-2010, 05:15 AM
you could do that, but I don't think you'd be happy. I'd replace both
Old 02-25-2010, 08:06 AM
It would probably look funny if there was two different shocks on there. But if you do run a better shock with the older one, then it isn't probably going to work as good as it could. I would be more inclined to just run a real good single shock instead. Duals possibly could make the truck ride worse.
Old 02-25-2010, 08:12 AM
..........6" lift with regular shocks ...and they fit??..............if you do, at least put the same brand together on one side, one can only look at one side of the truck at a time
Old 02-25-2010, 08:50 AM
No they are the shocks that came with the lift. I believe they are pro comp and they are not the nicer ones. They are 4 weeks old.
Old 02-25-2010, 10:31 AM
Feedback Score: 5 reviews
Bilsteins correctly valved would be best.
