| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
HEADLIGHTS
Well last night at about 10pm I finished installing my new '07 Harley Headlights...what an adventure!
In the end it really wasnt that difficult. For one, I'm glad I checked out some of the threads on this project, because the cutting diagram that came with my new headlights was not very helpful at all. Also I worked my dremmel so hard that the chuck lock sheared off! And of course those new lights look ridiculously nice, so i'm pleased. And for $160 on eBay with harness included, not a bad purchase. Here are my tips for those of you who are embarking on this project... 1) Use a rotozip to cut the grille pannel, a REAL rotozip. I killed my dremmel using rotozip bits in it. (having a jigsaw on hand helps alot) 2) You definately need a dust mask....its not plastic, its fiberglass and I was itching all over by the time the project was done. 3) Either buy a new set of light plugs or be very cautious when unhooking the old lamps: the plastic is very brittle and I had a few little corners and tabs break off. 4) No matter how well you cut, its a tight fit....make sure you mask the very corner of the fender, its kinda in the way. Pics to come>>>> -wes |
yeah it isn't as hard as you think it is going to be. It is a great upgrade!!
I have a question for anyone else that has put the 05 lights in. Does is seem to anyone that their lights shine a little bit too high? Mine fit perfect and aren't pointed high at all but for some reason the beams look high. The high/low works fine and highs aren't staying on or anything. Doesn't bother me any but seems to bother other drivers somtimes. haha
yeah I pointed mine down a little...
How did you manage that? I thought about it a little but ran out of time before I had to leave town again. Since the holes on the lights had to line up with the holes in the header panel I didnt really have any ideas. Was also thinking about just getting the 05 header panel to.
![]() Kinda, Obnoxious & Self Centered - isn't it?.... |
Any idea how the F to adjust these things? Its driving me nuts....is it really this one reverse torq screw? and where do you get a driver for that....im stumped
i got mine at NAPA... for the "reverse" torx
if you have a small 1/4 drive socket set,try to find one that will fit over it.That's what I used.I can't remember the size but it WAS small.
You really don't have any side to side adjustment, but as for the up and down, you should:
- Park as close as possible to a wall or garage door on flat ground. - Use a small socket that fits snug over the star/torx adjustment screw to get both lights even. - Mark where both lights shine on the wall. - Back the truck up to about 25ft away and adjust both lights until they shine about 2-3 inches below where they did right in front of the wall. |
