need to lift front of truck - Ford Powerstroke Diesel Forum
Old 01-20-2010, 11:16 AM
I have a 99 F250 4x4 and the frontend of my truck sit lower than the back. I am puttin big bumper on the front of it so I know it going to weight another 250 pounds. What would be the best way to raise it up..thanks
Old 01-20-2010, 11:21 AM
Pointless Poster
get a shackle nad hanger kit from Sky's Off-road Design - Home. i have mine sitting in my living room right now just gotta wait till trucks back runnin to put it on
Old 01-20-2010, 11:28 AM
Plus my front tires hit when I turn sharp...I been lookin and some places say u have to replace the track bar do u have to do it on that one and why is it u have to replace it... Has anyone used that mini pack kit that goes under your leaf springs?
Old 01-20-2010, 11:39 AM
Pointless Poster
Ford Superduty 99-04 Leveling Kit - Sky's Off-road Design
this will keep your factory ride but lift it up. the min spring packs will make it a stiffer ride
Old 01-20-2010, 12:58 PM
DJM DJM is offline
I got my 2.5 drop shackle from Rubicon Express
Old 01-24-2010, 11:54 AM
would the shackles work if i already have a 4 inch lift?
Old 01-24-2010, 01:41 PM
Yes, the shackles will work. I had a 6'' lift, & I put the 2'' shackles from pro-comp on it. Works great.
Old 02-07-2010, 01:41 PM
Im doing the same as you with the 6 inch lift and 2 inch shackles. How much room do you have running 38s? I was hoping to run 40s or 42s. Do you think there would be enough room without rubbing the bumper, fender wells, or leaf packs?
Old 02-07-2010, 11:13 PM
DJM DJM is offline
I can tell you this much if your gona run a 40 or 42 your probably gona rub the spring pack just because of the width those size tires come in unless you have one heck of a backspacing.
Old 02-08-2010, 03:22 PM
Feedback Score: 5 reviews
To run 40-42" you need a 12" lift unless it never sees a bump and turn's at the same time.
Crossover steering DS's etc will be needed.
