| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
PLEASE READ,UPDATE WITH IMPORTANT QUESTION
It didn't work.I cut the green wire with the black tracer that was in spot 13,grounded it,and no foglights???They wouldn't come on at all.I checked the fuses and relay's...all good.Un hooked it,hooked back up the way it was and they worked.Tried it again thinking somehow I screwed up and the same thing happened.I read what trucks it won't and will work on and it should work on mine.I did do the ridin durty mod where I spliced the wire out of the headlight switch to a toggle switch the other day.I messed with that trying to get it to work aswell,but nothing.Does the brite box mod not work in conjunction with the ridin durty????
I also just realized that when I turn my lights on,my lows and fogs are on but when I switch to brights my lights go out completely except for the fogs.Did I blow a fuse or a relay?Any ideas which ones to check?
Sorry I can't help but here is a
.What is the "ridin durty" mod? BTW that is a stupid name for a mod.
Does your truck have the factory "daytime running lights"?
no sir.It does not.I just made a new thread with this question.Sorry,I got no respones on this orginal thread so I made a new one so it would catch peoples eyes!Thanks for responding.After I realized the mod didn't work, I did re-connect the wire that I spliced back together like it was and double checked it to make sure it was good and it was.Is there a seperate relay or fuse for the highbeams?
do you know which ones to check.I don't have a manual.I know which is the fogs(#43) but thats all I found online.My fogs are good they work all the time(except for when the brights are on like normal since the bb mod didn't work)All I need to figure out is which fuse is for the brights and I'm sure that will fix it.In fact,I think I heard it blow when I was messing around with the mod........
just found the answer....30 15A* Highbeam headlamps
here's the link if anyone needs it for future refrence i have a 2003 ford f250 and it doesn't have a fu... - JustAnswer |
That "bright box" or "fog light mod" will work on your truck. I'll try to find my manual and then talk you through it.
where you can run your parking lights and fogs at the same time if your truck is one of the models that won't do it from the factory.I didn't name it,one of the other forum members did.I thought it was funny aswell!! But he did it and can name it whatever he wants in my opinion!!! |
