| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
2.5" Front mini add a leafs-ANY GOOD?
Looking to get the front of my early 99 up a little hoping to fit some 35's under it comfortably. Anyone use these? Are they ok to do?
You need a 4" lift to run those 35's. I have X-codes and a BDS 2.5" shackle kit and have cut the driver side wheel well a bit and it still rubs on a hard left.
We stuck 35's under a stock superduty and there was some rubbage but not too bad. I would think 2" would probably be enough...
My truck must be an odd duck
It is all in the offset of the wheels...
What offest where they? Mine are 18x10's with whatever offset Truck Toyz told me to get.
I have a 01 with a add a leaf. I have a 20x9 wheels with a 0 offset with a 35x13.50x20 pro comp. They rub on the leaf spring because I really need a -12 offset wheel. But 35's will clear on a leveled superduty.
4.5" BS is what should be used.
That is what I have. For some reason mine rub on inner fender on the driver side which has been trimmed once and I have x-codes and 2.5 shackles.
I run 38'' toyo M/T on my truck and I just have 2'' block in the rear and 2 more leave in the front..no drop pitman arm no drop track bar all stock and its look nice...I just back up my inner fender and just a small cut in my front bumper....
