Adding fog lights to late 99 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-29-2009, 08:59 AM Thread Starter
mick883's Avatar
I just bought a set of factory fog lights for $50. I figured I could just put them on since my light switch pulls out. I looked inside my bumper today and it doesn't look as though I have the holes for me to put the lights and brackets onto.
Were there 2 bumpers for the late 99? One for a fog light setup and one without???
If so, does anyone have pics of this setup and how to install the fog lights on a bumper that has no holes for the fog light brackets?
Thanks.
"Late" 99 F250
Crew Cab, Short Box
Straight piped (no muffler but rest of exhaust stock), 35" BFG A/T
DIY NAPA 6637 Intake
Zoodad mod (my version of it)
Leveling kit
4" exhaust
TW Chip
NOW NEED WW b/c TW is giving me turbo surge
[B][COLOR="Blue"]Future needs:
Guages
mick883 is offline
post #2 of 8 Old 11-29-2009, 12:30 PM
layson's Avatar
Quoted: 82 Post(s)
I am really surprised they are not there. Make sure there is enough material left and then just drill and mount them.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 8 Old 11-29-2009, 04:02 PM
My late 99 is the same way- I don't think any of them had fog lights. I don't have a wiring harness for them, or the designated place to mount them. You can probably use the factory switch somehow, but you should put the fog lights on their own circuit. Do a search on here, and you'll find lots more info.
Late 99 F250 ext. cab 4x4 Lariat 7.3
robthebuilder is offline
post #4 of 8 Old 11-29-2009, 04:21 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
just drill em in the bumper. i still need to get the harness somehow.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #5 of 8 Old 11-29-2009, 05:26 PM Thread Starter
mick883's Avatar
I am not sure. I will try though. I think I may just run them on their own circiut. Just cut off the connection and run the wires to a direrct hot and then put the ground on a toggle switch in the cab. Any reason why not?
"Late" 99 F250
Crew Cab, Short Box
Leveling kit
4" exhaust
TW Chip
Guages
mick883 is offline
post #6 of 8 Old 11-29-2009, 06:26 PM
joeniel's Avatar
Send a message via AIM to joeniel
Maybe, use a relay thats triggered off of the parking light circuit, which would put them on with parking lights only, as well as with headlights (since parking lights are on with headlights). If you want an off option, when you splice into the parking light circuit, splice in behind the headlight switch and put a toggle in mounted somewhere in cab, then go to the relay. On relay: #87- fused 12v in, #86- wire from toggle switch from parking lights, #85- ground, #30- to fog lights. If you dont want a toggle, then splice into parking light curcuit under hood and go rite to 86. Doing it this way, you wont pull power from the stock circuits, and there wont be any extra switches if you dont want any. The only time the toggle would be used (if you choose to put it in) would be if you wanted the fogs off for some reason. You can get an auto relay, as well as a 3"x2"x1" project enclosure from radio shack (taken from stumpy's reverse light mod).
Someone correct me if I'm wrong.
2002 F350 7.3
PHP FU, Isspro's, DIY Intake, 5" Stacks, WW, 08 Mirrors/Gate/Tails.. etc
Pics and full list of mods
Waltham, MA
Looking for an 8 foot bed in the New England area!
If you have one, or know who does, please PM me.
joeniel is offline
post #7 of 8 Old 11-30-2009, 09:14 AM Thread Starter
mick883's Avatar
Wow not that is some detail. i am a little lost with the "#87-fused......etc" not sure what all those numbers and wires are. Can you dumb it down for me...
"Late" 99 F250
Crew Cab, Short Box
Leveling kit
4" exhaust
TW Chip
Guages
mick883 is offline
post #8 of 8 Old 11-30-2009, 09:37 AM
joeniel's Avatar
On a relay (like the one used HERE in stumpys write up for reverse lights), there are 4 terminals. 12v in, 12v out, ground, and on/off. They are numbered 87, 30, 85, 86, respectively. Basically, when the parking lights are turned on, the powered wire from the parking lights acts as a switch/trigger that tells the relay to connect the 12v feed (which you have to fuse) with the 12v out, so you get power to the fogs, but arent straining the existing system or blowing fuses etc. If you put a switch in the wire the comes from the parking light circuit before it gets to the relay, you can turn it to the off position, so the powered "switch" line wont make it to the relay, and the lights wont turn on... but once again, you dont need the toggle if you dont want it, or you could put it in, and leave it on all the time, and hide it, just incase you ever need to turn the fogs off (like when you go for inspection, youd want to turn them off so they wont be on with the high beams).
Once again, basically Stumpys mod, but activated in a diff way.
2002 F350 7.3
Waltham, MA
joeniel is offline
