F650 hood conversion - Ford Powerstroke Diesel Forum
Old 11-27-2009, 07:11 PM
Talking F650 hood conversion
Has anyone ever put a f650 tilting hood on a f350 or f250 sub frame and make it all work?
Old 11-27-2009, 07:15 PM
You would probably need a massive body lift to do it, my dad has a 650 and the cab is probably a good 8 inches off the frame.
i dont think it would work... arent the body lines different on the 650s
Old 11-27-2009, 07:24 PM
If it aint a CAT itsa DOG
I think someone on here as done it before. The hoods are wider than a SD though. It would almost be easier to weld the factory parts together and put them on hinges to tilt.
Old 11-28-2009, 06:41 AM
I saw the pics of one a few years ago. The front axle dosn't line up with the wheel well, and you will need to make mounts for everything that isn't bolted to the motor or firewall.
Old 11-28-2009, 06:57 AM
Yep that is true. You could do like my freightliner and leave the inner fender wells on the body so you can still mount stuff to them. THen just have the hood come down around the fenders.
Old 11-28-2009, 07:43 AM
aluminum tubing engineer
here ya go...front looks fine, but the trailing edge does not work at all...
Old 11-28-2009, 09:58 AM
that is F'in ugly..wow next step to useless...
Old 11-28-2009, 10:30 AM
lol...i was tryin to be nice
Old 11-28-2009, 11:20 AM
Wow I guess some people just like to have something that looks like everyone elses ride instead of being a little creative and can only express there comments as criticism. Here is a picture that I found and it dosn't look that bad at all.
[IMG][/IMG]
