Tow Mirror Blues - Ford Powerstroke Diesel Forum
post #1 of 20 Old 11-18-2009, 05:11 AM Thread Starter
ScottnID's Avatar
Question Tow Mirror Blues
Hello Ford fans!
Have a question ... has any one had the extendeable tow mirrors "stick" in the extended position. I recently bought a 99 F250 and while I tried sliding the drivers's mirror in and out, I totally forgot to do this to the passenger side... low and behold, that mirror is seriously stuck in the out condition...
I hve tried silicon spray, graphite... nothing will budge it... how is the mirror plastic held on (don't want to break clips)... thought I might try takeing the backing off to see why this thing won't budge...
Thanks for any help... See my truck in the garage!
Scott
ScottnID
99 F250, 7.3 PSD, Extended Cab, 4X4, Short Bed; Running Boards; 4" Banks Monster Exhuast; Pillar Mount Pyrometer.
ScottnID is offline
post #2 of 20 Old 11-18-2009, 09:25 AM
Send a message via MSN to Rockstar Edition Send a message via Yahoo to Rockstar Edition
post up a pic, they actually sit out just a hair( about an inch and a half ) of metal post will be showing when it's in the closed position. so put up a pic and we'll be able to help you more. what you can do is use a towel( I had to do this on my truck when I bought it to free them ). put a towel folded over on the mirror and gently tap it with a rubber mallet, it will break free. but post up that pic first and we'll tell you if it's closed or extended. don't forget to use a ton of spray before you go malleting it to death.
Chad
Rockstar Edition is offline
post #3 of 20 Old 11-18-2009, 09:31 AM Thread Starter
ScottnID's Avatar
Thanks Chad... I can post some pics later today after I'm home from work, but I know its in the exteded position cause I have compared it to the driver's side that slide in and out fine... little nervous agout tapin it with a hammer, I've bangged it pretty good so far with the heel of my hand and it just don't budge ~ doesn't feel like it will move at all...
S
ScottnID
ScottnID is offline
post #4 of 20 Old 11-18-2009, 09:33 AM
yeah I was worried about the same thing when I bought my truck. my buddy actually showed me that trick on how to do that. just be real careful and be sure to hit the very edge( BE SURE TO USE THE TOWEL ) as it will help soften the blows from the mallet. and I just looked at your gallery and yes it's stuck in the OPEN position, try that trick. IT WILL WORK.
Chad
post #5 of 20 Old 11-18-2009, 09:37 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
"C'mon, Scott! Put a little muscle into it!!!" LOL. Good luck, man.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #6 of 20 Old 11-18-2009, 08:56 PM
the1laf's Avatar
99-01 mirrors
Does the mirror only fold towards the back??
If it does then you have stock 99-01 mirrors that don't move in and out.
same here
the1laf is offline
post #7 of 20 Old 11-18-2009, 09:25 PM
same here
Mine only fold towards the rear, and both slide in - out.
Austin G is offline
post #8 of 20 Old 11-18-2009, 09:35 PM
same here
that is completely NOT TRUE. all the towing mirrors were extendable and ford never made them stationary in the EXTENDED position. use my method and you'll get it worked out bud. good luck and let me know how it works out for you. and I say you're wrong on this because my STOCK 2000 mirrors folded, extended and all/
Chad
post #9 of 20 Old 11-19-2009, 06:36 AM
the1laf's Avatar
it looks like the 99-01 mirror, sh!t that sticking out there. Keep trying!!
Chad thanks for clearing that up! Mine never have moved on e99,00,&01 '350s.
the1laf is offline
post #10 of 20 Old 11-19-2009, 07:08 AM Thread Starter
ScottnID's Avatar
Thanks all... I'll geter unstuck!
S
ScottnID
ScottnID is offline
