| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
9005 in fog lights?
I was reading on FTE that you can put a 9005 (i think) headlight bulb in the fogs to make them alot brighter. Anyone know if this is true? Will the connectors match up or do they gotta be changed? And how bout the wires.. heavy enough gauge to handle the higher wattage?
This is true. I have not done it but I know you can. I am just going to save my money for HIDs
Yep they work fine...
Did this on my old 04 and now they are in my 2006 plugs right in ..
What about the wire harness tho? I was reading a bunch of guys said to handle the higher wattage bulbs the harness needs to be replaced with a heavier gauge wire?
That would probably be wise to do. I didn't though...
how much brighter are the 9005s?
by the time you buy the bulbs and do the wire harness your already pretty deep into it money wise... why not just save up and do a better investment like a full HID setup?
No need for a harness and you can get bulbs that are 70% as bright as hids for less than $70.
Stock housing isn't designed for Hids.. |
