| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
where is the "ridin dirty" write up???
I'm trying to find the write up for running the fog lights and just the parking lights at the same time.I don't want to run a toggle switch if I can help it.Anybody have the write up saved or be able to explain to me what I need to do? I'm doing the fog light/high beam mod this weekend,kinda wanted to knock them both out at the same time ya know.....Thanks for any info you can help with!
thanks boss, but that mod I got saved.Trying to figure out how I can turn my switch to the parking light postion and have my fog lights come with them.I found a right up on it at one time,but like an idiot I didn't save it!! all I can find is this but I don't want to run a toggle....
Foglight and Hi-Beam Mod |
pop out headlight switch, wire from parking light hot to fog light hot. i put a switch but its hidden under dash. havent touched it once. keeps them on when headlights are on too, so you dont gotta pull the switch out anymore. i can try and find the color wires if youd like, but thats the basic idea.
i can turn my park lights on and my fogs on at the same time. I didnt do any mods. It came like that from ford.
Some have it, some dont. I believe 03 and on has it, and some 02 and earlier. All depends. Those who dont can do that mod ^^
wish i had foglights...
Mine is a late 03 and doesn't do it.Thanks for the link p stoked b!!!! what do you guys know about the dremel mod that they spoke about in the above link
That was me with the link, but ok
hah just messing around.. bored at home The dremel is basically modifying your stock switch so that it can pull out in the parking light position. You have to shave off a piece of plastic so it can do it, and then I believe you have to do some stuff to the wiring. Easier to do it with the link I provided. You dont run the risk of ruining your headlight switch, and it works good. They turn off and on with the parklights (which are on with the headlights too).. you can never accidentally leave them on, even if you leave the toggle you spliced in for it on 24/7 (like me). |
