Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 10-31-2009, 06:40 PM
Dudenhymer Dudenhymer is offline
Looks like the a** end sags
Hello all. About a month ago I bought an 03 F250 superduty 7.3 short bed supercab with a 4" lift and 315/75/16s. Not sure exactly what kind of lift it is but more than likely a block lift like Pro-comp or something. I'm new to the lifted truck world. From certain angles it looks like the back end sits lower than the front. The distance from tire to fender is actually more on the back than on the front so I know it's just an illusion but... I was wondering if there was an easy way to add another 1/2 inch or so of lift in the back to offset this look. Do I need t get a set of 4 1/2 inch blocks or do they make some sort of spacers to slide in??
Thanks.
Old 10-31-2009, 07:56 PM
1tonpower 1tonpower is offline
Thanks.
every lifted 250 ive seen rides low like that....get some airbags in it
Old 11-04-2009, 04:30 AM
Anyone have any experience with the Firestone Riderite or Sportrite rear air suspension??
Old 11-04-2009, 04:48 PM
layson layson is offline
airbags or just swap out the block...
Old 11-05-2009, 06:07 PM
Do they make a 4 1/2 inch block??
