| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
leaf spring bushings?
does anyone know where to get some stock bushings? other than the stealership?
U try Autozone or Napa? They should be able to get you some if they aren't in stock.
Are you hunting stock bushings for a reason? Polyurethane is probably less expensive than OEM and gives a better feel.
I tried to get aftermarket bushings for mine but pro com said they signed a deal w/ ford that they couldnt make aftermarket one or so said trhe guy at procomp when I called today can anyone help me out? I dont wanna really spend 44 bucks on stock ones! thanks!
I was just at my local truck shop and they have the info on there computer. If you cant locate them let me know i can give you there number. otherwise search for Farmington truck center in Farmington MN.
I dont think you will find aftermarket as they are pressed in flush. |
