Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 10-29-2009, 08:46 PM
02lariat7.3 02lariat7.3 is offline
Send a message via AIM to 02lariat7.3
a few mirror questions
i got my lighted 06 mirrors today,now i have a few questions one has a cracked lense, how do i get it out without damaging the mirror?, since i am replacing at least one anyway, are the smoked recon replacements any good?,also, i have power towing mirrors on my truck now, my new ones have power/lights/heat, how am i going to have to wire this up? i know ill have to run wire for the lights/heat,but will it plug in so at least the power works? thanks for reading and any imput is greatly appreciated!
Old 10-30-2009, 02:35 AM
99250on14inches 99250on14inches is offline
hey bud,
the recons are EXCELLENT. I had them on my old truck. as for the wiring, NO it won't plug right in, you'll have to get the schematic, located somewhere on here, I can't remember where. Ill try to find it somewhere, you'll have to cut the plug and find which wire does which, brown or black is ground. what I did was grounded it and put power to each specific thing, then ran the two wires together and did it that way. as for the lights what I did was went under the dashboard with a test light and turned the ignition to acc or on( whichever turns the signal on) and probed until I found which was which. good luck you'll love the look when you're done, you'd love the 08's more though......careful though, people steal stuff...
Chad
Old 11-09-2009, 04:55 AM
Dave Willis Dave Willis is offline
Mirror Wiring
On lighted/heated mirrors how does the heater work. Does the heater need to be on an on/off switch, or some type relay that turns them off automaticly after a period of time, (Kinda like a rear window defroster) I understand all the wiring except rhe heater wiring.
Thanks.....Dave
Old 11-11-2009, 08:12 PM
Kyle_KleinSS Kyle_KleinSS is offline
My 99 only had power and i put power/heat on them. The stock wires were the same color the 3, then there was a black and black/white stripe sire. The black was ground, the striped wire was the hot wire for the heaters. I found a whole writeup for the lighted mirrors if I find it ill let you know.
