Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 10-28-2009, 06:29 PM
99BEIGEPOWERSTROKE 99BEIGEPOWERSTROKE is offline
Rust on Wheel Wells
I had chrome trim on the wheel wells of my truck. I just took them off and found out I had rust bubbles on all 4 wheel wells in spots. I sanded them down a little to get rid of the bubbles and put bushwacker flares over them to cover up where I sanded. Do you think it needed to be primed or will it be ok since the flares are covering it up? Will it rust worse or be ok?
Old 10-28-2009, 06:31 PM
dieseldan2005 dieseldan2005 is offline
If it aint a CAT itsa DOG
It will definately rust again and soon. I had the same rust and i ground mine down to metal and then herculined over it. I found that i had a hole thru in my cab corner and now even though the outside is covered, its rusting from the backside though. You gotta prime over the bare metal.
