| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
8" Lift
So i ran across an 8 inch pro comp lift with adjustable soft ride shocks and front and back leaf springs and pitman arm. my truck is a long bed, so my question is will i require any mods to run an 8" lift? i was under the impression that there was shimming involved or something... any feedback will be appreciated
Usually you will need a longer front DS and sometimes to get rid of the vib's a CV added after the carrier bearing.
Cary |
Drop down bracket for the rear driveline piece of 1" box tubing will work and yah longer front drive line.
my stock front driveshaft works on my 8" fabtech lift.... and in the rear u need a carrier bearing shim kit... up front i reccomend longer front brake lines
