lift kit? - Ford Powerstroke Diesel Forum
Old 10-06-2009, 02:45 PM
lift kit?
OK so last night I picked up a used lift rims and tires, for what i think was a good price. The kit is a explorer pro comp looks to be 6.5 lift. It came with front and rear spring packs 22415/22610 and drop pitman arm, u-bolts ,2.5 blocks and shocks. My ? is what else do I need, I am guessing sway bar extended links and drive shaft alignment kit. I have tried to search for these but have not found them, any advise on what else I need and where to find them would be great!!!
sorry so long!
Kit came with M/T classics and BFG 35-12.50-16.5 I know I will most likely need bigger tires but for now will work.
Old 10-06-2009, 03:07 PM
A carrier bearing drop is a must...you don't need much... mine didn't even come with one. It is fine but eventually wore it out.
Old 10-06-2009, 03:20 PM
So just that and the sway bar extended links and GTG!!!!
Old 10-06-2009, 03:33 PM
sounds like you probably have everything. The GTG is a must too
