Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 10-05-2009, 09:13 PM
trucktractorman trucktractorman is offline
Wheel Spacers
Does anyone know of a good wheel spacer that wont compromise load capacity? I have 35's on a 4in. lift and I rub when i turn to sharp. If i put spacers i need to put them on the front and back so that the truck doesnt look weird. Any suggestions of ideas????
Old 10-05-2009, 09:51 PM
RJM06590 RJM06590 is offline
Built Not Bought
i put napa 1/4" spacers in the front and rear of mine and it took almost all the rub out with the 37s and made my old 35s clear jus fine. also depends on your wheels
Old 10-05-2009, 09:53 PM
EvolvedMS EvolvedMS is offline
I just don't trust spacers in any way...
Old 10-05-2009, 09:59 PM
Built Not Bought
i check them often and have never had a problem with the lugs backing out. i know guys that have doubled the 1/4s to make a 1/2 and still haven had probs
Old 10-06-2009, 02:26 PM
Have you pulled any heavy loads with them? If yes, how have they held up?
Old 10-06-2009, 02:31 PM
mudrunninpig mudrunninpig is online now
D80 Axle Snapper
call fred goeske at wheeladapter.com he can make what you want. I am runnin his spacers with 37's for 60k now and I haul 12k on a weekly basis. I have had no issues with his spacers.
Old 10-06-2009, 05:55 PM
Built Not Bought
i have but not real long distance but no probs
Old 10-25-2009, 06:38 AM
tturbonegro tturbonegro is offline
does everyone use extended lug bolts? how big of a spacer do you use without using an extended lug bolt ???
