Lift + shackles?? - Ford Powerstroke Diesel Forum
Old 10-05-2009, 01:52 PM
Once you go black......
Send a message via MSN to CanadianDiesel
Lift + shackles??
Truck needs some help up front.
I was thinking of these Rough Country springs PLUS a shackle lift? Does this seem like a good or bad idea?
this is the spring pack on ebay:
00-04 Ford F250/F350 Super Duty 2.5" Lift Kit:eBay Motors (item 330360409137 end time Oct-15-09 10:31:16 PDT)
Old 10-05-2009, 02:20 PM
Old 10-05-2009, 04:20 PM
I think that lift looks like a good deal but i would stick with that, cause i would think it would be to high in the front with nothing in the back.
Old 10-05-2009, 06:09 PM
Sounds good. Yeah i know what you mean, but right now I have brand new leafs at the back. the gap is 13" in the rear and front is only at 7" so I have a long ways to go til im even with the back if you know what i mean...
I don't want it perfectly level but I am looking for about 3-4" of extra rise at the front
Old 10-06-2009, 07:18 AM
I have lift springs and a BDS shackle kit up front. It's fine.
Level is cool untill you put a load on the back. Almost level works well. SOme guys think that level means nose high. I guess it is preference.
I like to use my eye when it comes to leveling a truck. That is what others see it with.
Old 10-06-2009, 08:16 AM
Feedback Score: 5 reviews
A much better riding lift would be with 4" hangers and your stock springs or just add X code springs and a adj track bar.
Old 10-06-2009, 06:34 PM
Yeah I'm not looking for perfectly level, I know what you mean...it looks really weird as soon as you load it up it sits ride down.
By 4" shackle do you mean it's 4" longer than stock?
Old 10-07-2009, 03:58 AM
I have X-codes and BDS hangers with a skyjacker trac bar bracket. Which IMO is better than the adj trac bar.
Old 10-07-2009, 11:39 AM
Yes a 4" longer set of front and rear hangers.
problem with using just a drop bracket as you did, it was made for the BDS lift not the additional 2" a set of X codes will give you..still need a adj bar with the drop bracket as your axle will shift 1/2-3/4" from the additional lift.
Old 10-08-2009, 03:39 AM
I bought a 2 1/2 set of BDS hangers and the Xcodes. Equals damn near 4". I didn't have to use the cummalong technique. Bolt slid right in.
