headlight? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-05-2009, 08:41 AM Thread Starter
lsmith33's Avatar
Send a message via AIM to lsmith33
headlight?
will stock headlights from an 06 fit on my 99??
thanks
Early 1999 F250
Ext Cab Swb
Foil Delete
Dyi intake
5" dp back exhaust
37" boggers/ leveling kit
AD injectors
DI custom 4 pos. chip
Big dreams on a 20 yr olds budget
lsmith33 is offline
post #2 of 6 Old 10-05-2009, 08:51 AM
Raul@Stealth Automotive's Avatar
yes and no.... they will bolt up but you need to cut your header panel to make them fit... and you also need a 9007 to H13 harness to make the headlights work
-Raul
Raul@Stealth Automotive is offline
post #3 of 6 Old 10-05-2009, 08:57 AM Thread Starter
lsmith33's Avatar
ok thanks what has to be done to make the newer grills fit??
Early 1999 F250
Ext Cab Swb
Foil Delete
Dyi intake
5" dp back exhaust
AD injectors
lsmith33 is offline
post #4 of 6 Old 10-05-2009, 09:03 AM
their is a write up on what you need to cut on the header panel and i always forget to save the link... im sure someone will post it up... as far as the new grill goes you will need to cut about an inch off the bottom to make it fit....
-Raul
post #5 of 6 Old 10-05-2009, 09:28 AM
HOUTX01X's Avatar
Quoted: 4 Post(s)
'05 Head Light Conversion Template/Guide For Cutting
Cutting an 05 grill to fit a 99-04
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #6 of 6 Old 10-05-2009, 10:16 AM Thread Starter
lsmith33's Avatar
thanks guys
Early 1999 F250
Ext Cab Swb
Foil Delete
Dyi intake
5" dp back exhaust
AD injectors
lsmith33 is offline
