Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 09-16-2009, 04:17 PM
85_305 85_305 is offline
Sagging driver door... wth??? I'm pissed!
So all of a sudden out of nowhere the other day, my ds door is sagging!! It takes considerable amounts of effort to close it w/out it still being propped open a bit. I can see that the latch on the front door is just a little low for the receiver on the rear supercab door. Is this normal? Is it adjustable? I cant believe this happened out of nowhere
Matt
Old 09-18-2009, 06:07 PM
robthebuilder robthebuilder is offline
most likely your hinge pins and bushings are worn out. You should be able to find replacements in the "help" section of you local parts store.
Old 09-18-2009, 08:11 PM
Are they easy to do on these?
Old 09-18-2009, 08:15 PM
TurboSevenThree TurboSevenThree is offline
I miss the 90's. =[
They're not that bad on anything. But I know on a GM you have to have a special tool for the spring.
Old 09-18-2009, 08:54 PM
Good deal I'm going to look into it. Its pissing me off lol
Old 10-22-2009, 07:39 AM
blue72 blue72 is offline
My driver side door does this. Anymore info on this?
Old 10-22-2009, 11:02 AM
Ya mine too.. but the thin is when I bought it, it didn't do it. A month or so later it started. I couldn't believe out of nowhere it started.
But like they said above just buy new hinges. Seemingly cheap and easy to do
Old 10-23-2009, 11:50 PM
Rob454 Rob454 is offline
I did the bushings on my little GMC. That little tool is about 5$ and the bushings are cheap.
Old 10-27-2009, 10:06 PM
ryansjake ryansjake is offline
I got the same problem, I'm going to try doing the door bushings and see if that fixes it. It seems like they're just a bit tired after 10 years of door openings and closings
