Billet aluminum blocks on the rear - Ford Powerstroke Diesel Forum
Old 08-27-2009, 06:42 AM
Should I use these blocks to put the rake back in my truck.
I leveled the front but it is a tad bit higher in the back.
Can I stack them on top of F250 factory?
Has anyone had any expierence with them .
Also, I do pull heavy loads with my truck. I reguarly pull a gooseneck.
Old 08-29-2009, 03:04 AM
Send a message via MSN to Rockstar Edition Send a message via Yahoo to Rockstar Edition
in any case stacked blocks are NOT GOOD.....however if you pull IT CAN BE DISASTROUS order a single larger block, or if you tow heavy order the OUO traction blocks, they are blocks however they use a traction bar system that ties your blocks to the frame......except they're expensive.
Old 08-29-2009, 03:41 AM
Get some 350 blocks
Old 08-29-2009, 01:51 PM
get some 4" blocks there what you need
