| 99-03 7.3L Exterior Discussion Body and Accessories Talk |
No turn signals or brake lights
Want to know if I'm missing something. My turn signals and brake lights went out. I cecked and even changed the fuse, swapped around the relays and have nothing. Taillights work fine.
What am I overlooking? Please help as I use and tow with this truck. Early 1999 F250 Super Duty extended cab Is there a wireing diagram online anywhere or trouble shooting guide Last edited by splitpile; 02-16-2007 at 08:44 PM. Reason: added txt |
Have you checked the actual wires? You can get a haynes manual from just about any automotive store and they have the wiring diagrams in them.
is it cold out...cause my malfunction...er ah i mean multifunction switch acts up when it's cold out. I get only left turn signals and only the left side of fourways...more like two ways.
If bulbs ar ok, check the multifunction switch next. If you havn't changed it latley, it is probably bad.
