Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Exterior Discussion
Old 06-27-2009, 04:56 PM
Powerstroke W/smoke Powerstroke W/smoke is offline
2.8" Mini Spring?
I'm going to level my truck and i found these..anyone else using something similar? is 2.8" too much for a level? The rear of my truck has additional 2" blocks so the front won't ride higher.
99-04 Ford F250/F350 Super Duty 2.8" Leveling Lift Kit:eBay Motors (item 330334058076 end time Jun-27-09 18:41:56 PDT)
Old 06-27-2009, 08:23 PM
bump
Old 06-27-2009, 09:58 PM
Ozone-etr1 Ozone-etr1 is offline
jumpin jiggawatts
wow what a gip.........its like blocks for the front......wait there was something about useing thoes.......oh ya DONT!:rolf:
Old 06-28-2009, 02:01 AM
toddy toddy is offline
OperationSmile.org
Its a lil different than a block. The mini packs have a pin that runs all the way through so they dont pop out like a block would.
As far as those are concerned, save you money. The ebay ones are just flat steel that are tack welded a couple times. You would be safer and better off buying an actual mini spring pack from Icon.
