Broken Tranny Dipstick Tube Install Help??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-18-2014, 06:08 PM Thread Starter
I need some help on the best way to install a new tranny dipstick tube. Broken by the shop that installed new exhaust, and of course they never told me.... go figure... Any help, advise, pics, or video would be great. Thanks so much
2000 F250 XLT Lariat Crew cab SD 4X4 - 7.3
- 4" MBRP Turbo Back Exhaust
- CCV Mod
- AIH Delete
- Foil Delete
- Wastegate Mod
- EPBV Delete
- DIY Intake
- Zoodad Mod
- 295,000+ miles and still Kickin!!!!!
GOD BLESS THE USA!!!
Philippians 4:13 I can do all things through Christ who strengthens me!
Bentley1110 is offline
post #2 of 11 Old 08-18-2014, 07:00 PM
hansel's Avatar
Quoted: 94 Post(s)
You are talking about the top half, right????
Mine was shoe horned in from the bottom ounce the old one was unbolted and removed what was left of the tube after it broke at the weld where the bracket holds it onto the motor.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 11 Old 08-18-2014, 08:28 PM Thread Starter
Sorry, Yes I am talking about the top half. It seems just by looking it is going to be hard as heck to get it down behind the motor. Any tips will be greatly appreciated
- CCV Mod
- AIH Delete
- Foil Delete
- Wastegate Mod
- EPBV Delete
- DIY Intake
- Zoodad Mod
post #4 of 11 Old 08-18-2014, 09:40 PM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
I've never done one is our trucks but have done quite a few on other trucks when I worked in a trans shop. It should have one bolt holding it to the trans and one to the engine. Undue them both and give a good pull up on the tube to remove it from the trans. It will have an oring on the end so it maybe kinda hard to get out. Then pull the whole assembly out threw the engine compartment and install in reverse order.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #5 of 11 Old 08-18-2014, 09:55 PM
schlutzer's Avatar
Quoted: 18 Post(s)
On our trucks its two piece, its press fit into the trans, has a bolt that separates the two pieces, then the top half is attached with the passenger side top transmission bolt.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #6 of 11 Old 08-18-2014, 09:56 PM
Quoted: 760 Post(s)
It will be a pita. IIRC should only be 1 bolt that holds it onto the bellhousing.
Corey@CNCFAB is offline
post #7 of 11 Old 08-19-2014, 06:33 PM Thread Starter
Thanks for all the info guys. I appreciate all responses, I'm gonna give it a whirl tomorrow and see how it goes. Thanks again
post #8 of 11 Old 08-19-2014, 06:52 PM
I just put a reman trans in mine and had forgotten the dipstick tube and tried to put it in after the trans was bolted up and could not - I'm a professional mechanic too, with 45 years of doing this stuff. I had to unbolt the trans and slide her back several inches to get the tube down into place. The biggest problem was the exhaust downpipe, which I had not dropped to do the trans job and mine is a 4 in. pipe too. The stock 3 1/2" pipe might have let it pass by but can't say for sure. Dropping the exhaust a little would definitely let it go though, I'm sure. There is only 1 bellhousing bolt holding the upper tube bracket and the bolt is pretty easy to access with a long extension and flex socket.
skipmarcy is offline
post #9 of 11 Old 07-01-2015, 08:04 AM
Were you ever able to successfully replace the tranny dipstick tube? If so, any advice on the whole process?
dirtydzl is offline
post #10 of 11 Old 07-01-2015, 04:08 PM
Vannnce's Avatar
Quoted: 13 Post(s)
I had this exact problem when i put my reman. in last year
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
