ZF6 noise when in high gear - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-18-2014, 08:42 AM Thread Starter
I finished installing my transmission after getting it a new output shaft put in and after I filled it with fluid I started it to test it out and every other gear works fine with no noise, but when I put it in drive it makes a whirring sound. It doesn't sound really bad, but it is loud and worries me because none of the other gears made any noise.
I don't have the transfer case installed yet so I don't know if that could cause any thing. I figured if the noise was ok it would be making it in other gears.
Late 99 F250 XL Extended Cab Short bed
Everything manual
Volant intake, MBRP 4 inch exhaust
lawrencer12 is offline
post #2 of 2 Old 08-20-2014, 05:34 AM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
How did you fill it with fluid? The ZF6 has a sealed clutch master cylinder that needs to be replaced, it's a one piece design. You can't add new fluid.
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
