trans lugs when in cruise - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-01-2014, 11:05 AM Thread Starter
hitmanheutel's Avatar
Early 99 f350 2wd drw. Recently my truck began lugging like I am on a wavy hwy when I had the cruise control on at 65 MPH. The longer I let it go the worse it got, nearly violent. Hit the throttle and it goes away but as it slows down to the 65-70 range it does it again. I thought that it was a cruise problem but I can recreate it with a steady foot. Any thoughts?
BTW-I thought it maybe something as simple as tire balance but those checked ok.
hitmanheutel is offline
post #2 of 4 Old 08-01-2014, 12:13 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 410 Post(s)
How many RPM's are you turning?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is online now
post #3 of 4 Old 08-01-2014, 01:18 PM Thread Starter
Between 2000-2200.
post #4 of 4 Old 08-06-2014, 10:21 AM Thread Starter
I found that the ebps tube had a hole in it at the last bend before the manifold. I guess it was flapping the ebv and causing the lugging. Changed it and all is good.
