tranny slippage question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-25-2009, 06:33 PM Thread Starter
ok first off its an 2002 f250 7.3 8inch lift 38 inch tires. When i first start the truck everything is fine shifts fine no problems, as soon as it gets warm (around 180) it wont take off from a stop. When stopped and i take my foot off the brake the truck will not move on its own, if I'm stopped on a hill it'll roll backwards when i let off the brake. I have to rev it up like its building up pressure and then it'll kick into gear and go. no slippage if i get on it on the freeway or anything and doesn't slip in any other gears. I was thinking it might be a torque converter but don't know.
What do you guys think?
vegasmike250 is offline
post #2 of 8 Old 01-25-2009, 06:38 PM
Powerstroke W/smoke's Avatar
here's a bump bud
Sold!2001 F-350Lariat Lifted 7.3L CC, 5" Straight Pipe, DIY Intake, Foil-Delete, 6 pos chip, CCV Bypass, 37" Toyo MT, Gauges, Blacked out, 07 Harley Front-End.
SOLD!2006 F-250Amarillo 6.0L CC, 4" Straight Pipe, SCT-II
STOLEN ,2001 F-350Lariat 7.3L CC, 6pos chip, 4" Banks Straight-Pipe, Banks Comp Wheel, Custom Lighting, Foil-Delete, Intake.
Powerstroke W/smoke is offline
post #3 of 8 Old 01-25-2009, 06:39 PM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
Sounds stupid, but gotta start with the basics, have you checked your fluid level?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #4 of 8 Old 01-25-2009, 08:56 PM Thread Starter
ya fluid level is fine, bought the truck used about 30k miles ago, changed fluid when i got it and it smelled burnt. since then I have added a huge cooler and guages, never gets above 200, even in vegas summers
post #5 of 8 Old 01-25-2009, 09:01 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Changing fluid in a burnt tranny can kill it. You may have done it in
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #6 of 8 Old 01-25-2009, 09:04 PM
RedDye01's Avatar
My buddy has the same truck, same year, same big tires and the exact same problem. He says when he had his chip it, the truck would hesitate like you said then slam into gear. When he took it out, it did just what you're describing. Id be able to tell you what the problem was, but he hasnt had the cash to tear it apart yet.
Bellowed Up Pipes
GTP38R
T500 HPOP
HPX Line
RiffRaff FRX Line
JW Valve Body
4" Lift w/33's
6637 DIY intake
4" exhaust
Gauge
RedDye01 is offline
post #7 of 8 Old 01-26-2009, 03:11 PM Thread Starter
well I called john wood and he said it is most likely the center support has warn out and is causing pressure loss. He also said it may be as easy as something is blocking the filter, clutch material maybe, so ill take off the pan and see what it looks like.
post #8 of 8 Old 01-26-2009, 08:04 PM
RedDye01's Avatar
keep us posted
Bellowed Up Pipes
GTP38R
T500 HPOP
HPX Line
RiffRaff FRX Line
JW Valve Body
4" Lift w/33's
6637 DIY intake
4" exhaust
Gauge
RedDye01 is offline
