Found trucks limit. Hoping didn't push it over. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-06-2014, 09:03 AM Thread Starter
So I delivered a 35' rv trailer to camp ground for someone. Some crazy hills I had to pull but nothing truck couldn't handle.
However getting it into the spot might have pushed it too far. Had to back it up a grass hill and onto a concrete pad with about 3" lip. Had to go very slow since there was 1" clearence each side. Had it in 4wd. She got it in. Pushed onto the pad but then started to smoke. Burning transmission fluid.
Had some drive but obviously was slipping hard. I shut it down and let it sit.
Was fluid drips for a few feet to where I was. But nothing leaking as it sat.
After about an hour it started and pushed rest way and drive home with no issue. Shifted fine. No slipping and no fluid leaking.
However, the fluid is now clear, maybe a slight yellow tinge to it, hard to tell on dipstick but it is not red and stinks of burnt fluid.
Obviously fluid needs changed now. I cooked that. But think I damaged anything? Been thinking of taking it in and having it checked out but on these, it's not a cheap venture. Seems to run fine. No error codes etc
I don't have a temp gauge (I know I know. It's on list now!) but it must have been hot. I was pushing it beyond it's comfort zone.
7.3l DRW F350 4x4. stock, with exception of Airbags on rear, bilstein all around and 26k 5th wheel hitch. K&N filter for good measure.
dont try this at home kids!
Unclebobsuncle is offline
post #2 of 5 Old 07-06-2014, 09:22 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 367 Post(s)
When the fluid gets hot it'll leak out of the converter seal. If seen guys bake them and not have issues. Change fluid, filter, and drain the converter (very important). If your trans has been changed once before your converter may not have a drain plug. (Mine doesn't have one). To be on the safe side then take it to a shop and have them perform a trans flush. Those are a little more effective if you can't drain the converter.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 5 Old 07-06-2014, 10:16 AM
sbluke55's Avatar
Quoted: 546 Post(s)
Garage
Do what he said. Sometimes when you get a flush from lube shops they just change the fluid and leave the filter. Next time you have to move something like that put it in 4lo it will put less strain on everything. My guess is that the torque converter heated up the fluid tell it burnt and not from slipping because you where at low speed backing up.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #4 of 5 Old 07-06-2014, 03:06 PM Thread Starter
Thanks. Feel little better. It seems fine. I've had engine out twice. Don't remember seeing a drain on converter but wasn't really looking for it.
I tried to get into lo. It wouldn't engage. Not sure why. Xfer case is only couple years old but sometimes I think it gets in a bind. Letting it roll an inch often works but I was committed by that point so went with hi. In hind sight I should have dropped back down hill and tried lo again. Oh well. I'll fix her if need be. I always do. Until the next job.
post #5 of 5 Old 07-06-2014, 04:02 PM
hansel's Avatar
Quoted: 97 Post(s)
I just bought a 2001 that when I was inspecting everything I thought he was low on transmission fluid, so I didn't think about it too much because he told me the tranny had been rebuilt about 2 years ago.
Well after buying the truck I found out the fluid was actually clear
So I drained the fluid which was somewhat pinkish, but then as it got closer too being empty it turned clear, so what I did was replaced the filter cleaned the magnet, the flushed 6 gallons of fresh ATF. This way I flushed the converter and the valve bodies, it wasn't really shown any sign's of slipping the only thing the transmission does wierd is sometimes when it shifts into OD getting on the interstate the rpm's jump but then goes back down, I think it's the TC unlocking and locking real quick.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
