Transmission... hesitation? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 Old 07-01-2014, 06:50 PM Thread Starter
ThreeFitty's Avatar
So pretty much everytime I am at a full stop and then get on the gas( either hard or soft) I feel a hesitation where it waits a second and then you feel like a bump. You can sometimes creep off the line but once you get into it a hair you will feel that bump. Shifts fine. I also have a slight hesitation when going into the gear (park to reverse or any combination) and am wondering if all this is signs the tranny is going. I have a receipt from p.o saying they put a new converter and did something with 2nd and 3rd less than 1000 miles ago. What do you guys think? I need this truck for pulling my trailer daily and also plowing and want to make sure I take precautionary action if need be. Thanks
e99 F350 SRW 4x4 RCLB 7.3 Diesel (3/98)
-5" Diamond Eye Exhaust, straight piped
-RiffRaff 6637
-Sinister Diesel Coolant Filtration
-Hopefully a tune soon
ThreeFitty is offline
post #2 of 15 Old 07-01-2014, 08:43 PM
Macon's Avatar
Have you checked fluid levels?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 15 Old 07-11-2014, 04:52 PM
Colotow's Avatar
Location: Quit Iraq, got a house in Tooele, Ut, Back in a big wrecker playing in traffic!
My 01 did that, best way to describe it is it was hanging in 2nd then would drop into 1st when taking off, what does it do if you tap the throttle while holding the brake before taking off? this seemed to get it to drop into low and take off fine.
I rebuilt it last year, and did find a broken spring in the valve body that could have been the problem.
99 F350 CC DRW 4x4 PSD 6 spd 4:10 Programmed, 4"exh, 8" lift Kelderman 4 link air ride rear, southbend clutch (and arm!) 295/85R22.5's, AFE stgII gauges, push bar, 07 lights, recon smoked fender and rears, ARE shell, DynaTrak combo front,
, Short throw Shifter, Airdog, Regulated Return fuel, Coolant filter, Bypass Oil Filter. Next:BB Turbo, CAC, Injectors, HPOP, Head studs, and anything else I can afford
Colotow is offline
post #4 of 15 Old 08-16-2014, 06:32 AM
UncleLeos7.3's Avatar
I just bought an 01 that does this as well.
I am very interested in what you find.
I only have 80k miles.
UncleLeos7.3 is offline
post #5 of 15 Old 08-17-2014, 11:32 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
the slight hesitation going into gear could be from the shifter cable being out of adjustment.
also trans go shift kits will cause a monetary pause before going into gear.
from what you describe your slip joint needs to be greased. unhook the rear driveshaft from the rear axle. take the boot off and pull the driveshaft apart. put a little grease on the splines and reinstall everything the same way it came off.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 15 Old 08-25-2014, 06:58 AM
So....I had the transmission flushed and filter changed last week. On Saturday, I noticed a large spot on the driveway. I was transmission fluid. I took it in this morning and my mechanic says the front seal is leaking and they will have to drop the tranny to see if the torque converter has a groove in it.
He said this is a common problem with this tranny??? Any comments would be appreciated.
Mileage: ~80,000
post #7 of 15 Old 08-25-2014, 08:22 AM
I'm also getting the slip joint greased. Thanks Blue99Stroker!
post #8 of 15 Old 08-25-2014, 10:50 PM
Quoted: 249 Post(s)
I don't think its super common. I think the front seal usually goes bad from extreme atf temps
post #9 of 15 Old 08-26-2014, 04:49 AM
Been thinking the same about the trans temps. I bought the truck from my Aunt with 78k miles on it. I bet 60k was towing a 40' travel trailer.
Thanks again Blue.
blksmkstroke likes this.
post #10 of 15 Old 08-26-2014, 07:16 PM
Quoted: 249 Post(s)
sounds like its time for an upgraded transmission cooler.
check out the tru cool from dieselsite or fit a 6.0 cooler instead. both are better than the dinky stock cooler.
