Not shifting into O.D when cold - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-18-2009, 07:08 AM Thread Starter
Just noticed that when I am getting onto the highway that my 99 P.S.D doesn't shift into overdrive unless I let off the gas peddle when it cold. The fluid and filter were changed
at 68 k and it now has 95 on it now . I checked the level its fine and the fluid is clean, I also checked for codes and found none. Any suggestions???
cobrajet1 is offline
post #2 of 14 Old 01-21-2009, 03:02 PM
RadarRider's Avatar
Is this under regular street acceleration or highway? Is your rig modified with anything?
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #3 of 14 Old 01-21-2009, 10:08 PM
I am having the same problem.I finally got a code 720 which means output shaft speed sensor malfunction.It took mine like 2-3 weeks of doing this before it finally threw the code.I am gonna start another thread to see what the heck I need to do.Does yours go litely into overdirve also now comapred to what it use to?Mine does.
04 f250 egr delete,IDP 58v Ficm tuned,banks intercooler and piping,TSD SPD tunes,gogo DD solenoid,ITP RR kit, Fass 95g lift pump,Powermax turbo,ARP studded,08 pan and filter,6in and 35's on 20x12's with procomp traction bars
chappy is offline
post #4 of 14 Old 01-21-2009, 10:11 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
It wont go into OD if its cold. Once the truck and trans warms up it will go into OD. By holding off on OD it keeps RPM up to warm faster. Wait and see if it throws a code, if it don't its probably normal.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #5 of 14 Old 01-21-2009, 10:18 PM
Really?Mine always use to shift into overdrive when cold just would not lock the torque convertor till it warmed up a little.All my electronic ford trannys have done it that way.
chappy is offline
post #6 of 14 Old 01-21-2009, 10:20 PM
scuffs *****
Tyler's Avatar
The way my truck runs, lets say it already warm. It shifts to 2nd, to 3rd, then at 36-37 MPH it will shift to 4th, then drop right down to OD and lock the TQ. If its cold, it will stay in 3rd with the TQ unlocked. If I punch if really quick it will drop to 4th and lock the TQ, but not go to OD until the truck is warm.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #7 of 14 Old 01-21-2009, 10:27 PM
yeh ,that is the same thing mine is doing but mine has tranny issues and codes also right now.A month ago ,before my issues,it did not shift like this when cold.
chappy is offline
post #8 of 14 Old 01-21-2009, 10:28 PM
scuffs *****
Tyler's Avatar
Your speed sensor in the rear end that communicates with the trans may be going bad and freaking out your tranny.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #9 of 14 Old 01-21-2009, 10:41 PM
diesel_19's Avatar
mine doesnt go into overdrive in the cold neither
E99 f350 cclb 4x4 6speed
4in tb 6in tip
Ts chip
Ccv mod
Diy intake
Epbv delete
diesel_19 is offline
post #10 of 14 Old 01-22-2009, 12:27 AM Thread Starter
I think you are right, it started getting warmer here and it seems to be shifting better now.
Thanks
Cobrajet
