ZF6 weird noise in first and reverse - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-25-2014, 08:05 AM Thread Starter
Hey guys I recently got a 2001 f350 xl 2wd single wheel, it has 160k on it, I don't think it has had a clutch yet, clutch does not slip, but in low gear and reverse and first, it makes this sort of growling noise untill you get going a little faster than idle. I am new to these trucks, I was told it could be the pilot bearing, and if so is this something I should change right away ?, also the clutch disengages and engages just off the floor, I checked the famous bushing that goes bad and it is new lol, anyways your help would be great
Cheers
gman_ca is offline
post #2 of 4 Old 06-25-2014, 08:15 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Just gear rollover, many trucks will also do it in 2nd if you idle in a parking lot.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 4 Old 06-25-2014, 08:21 AM Thread Starter
oh wow, never heard of that before, you can hear it if I take off and you are standing on the sidewalk, so nothing to worry about then
gman_ca is offline
post #4 of 4 Old 06-25-2014, 09:22 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Nope no worries, its just exerting more load at the low speeds so you hear the gears meshing more. Mine sounds like a P-ed off pitbull while going through parking lots. Once you get better at playing the clutch its pretty easy to control while going through parking lots and stuff so it doesnt sound like you cant drive a stick.
You can reduce a bit according to schlutzer^^^with new syn fluid and archoil additive but i havent done it yet so no experience how much.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
The Following User Says Thank You to Rammstein1224 For This Useful Post:
gman_ca (06-25-2014)
