Flushing trans fluid, fluid comes out both cooler lines. - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-21-2014, 07:58 PM Thread Starter
I disconnected the return line to transmission where the hoses are between the radiator and engine to flush the trans fluid. I noticed that almost the same amount of fluid was coming from the hard line (going back to the rear of the trans) as there was from hose coming from the cooler. My first though is the cooler is plugging so I bypassed it and sure enough the flow about doubled but there's still a significant amount of fluid coming from the hardline when I'd expect almost none.
Does this sound like the cooler bypass isn't working properly?
mechanicboy is offline
