DP Tuner leave a footprint? - Ford Powerstroke Diesel Forum
Old 01-13-2009, 04:09 PM
Well after having my Tuner installed for a week I think I toasted my tranny, atleast it sounds like the converter is on its way out. I put a re-man Ford tranny in this truck back in Feb. so it is under warranty, but you know Ford is going to F#@^ with me because I put it in myself. Reputable tranny guy around here suggested that I go straight to Ford without him looking at it, said if it is under warranty let them deal with it before he gets his shop involved. So when I take out my tuner, will Ford be able to find a footprint and claim the tuner toasted my converter? Thanks
Old 01-13-2009, 04:53 PM
The Screwy HEUI
No. Just make sure you clear all codes & take your DP out before you take it down there. That way they have nothing to blame it on & refuse the work.
Old 06-25-2009, 07:43 AM
Living on a prayer
How did things work out for you?
Old 11-11-2009, 09:44 PM
I have been in to Ford a couple times since this, each time I remove the tuner and disconnect the battery to erase memory. Each time Ford tells me that it looks like my batteries have been disconnected before they do what I need I tell them that my battery charger is mounted on my work bench and I need to remove the batteries to charge them
No problems
Old 11-12-2009, 05:07 PM
The Screwy HEUI
No problems
Next time, if you want the Ford dealer to see if there are any pending codes, you should disconnect your batteries & then take it for a good drive; maybe about a half hour or so. This way your truck can regain it's parameters & if there are any important codes, you'll have them.
