4r100 pump mods? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-17-2014, 02:31 PM Thread Starter
Quoted: 8 Post(s)
4r100 pump mods?
I have a 2002 7.3 with 4r100, rebuilding it as of now, just bought a billet low stall converter from florida torque, I have a john wood valve body, rebuild kit with borg warner clutches, center support upgrade(machined center support with snap ring). Do I have to or should I mod the front pump, and if so what do I do? I also have the 6.0 trans cooler, and I welded the cooler bypass valve also. Any other mods I should do? Im going to be staying around 400-450hp. Daily driver, not much towing. Thanks guys!
2002 f250 ccsb 4x4, 250/200's,5 inch mbrp,itp boost fooler,regulated return/race fuel system, s&b intake, billet 4r100, swamps idm, lifted 2 inches, leveled, 35inch nittos on 18" s468, mishimoto intercooler, hydra tuning, detroit locker rear, dynomat, not done.........
2006 f350 ccsb 6.0, sct tuner 3015 custom tunes, studded, deleted, exhaust
mastertech79 is offline
post #2 of 6 Old 06-19-2014, 09:33 AM
corn binder's Avatar
Quoted: 2 Post(s)
Replace the solenoid block with one from a 95 E4Od, I did it in my 99. Eliminates the poor torque converter lock up characteristics. Replace the power valve with a. .427 valve& sleeve.
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #3 of 6 Old 06-19-2014, 10:02 AM
blue99stroker's Avatar
Quoted: 289 Post(s)
i know trans go kits come with a pump mod.
im guessing it just makthe pump put out more volume.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is online now
post #4 of 6 Old 06-19-2014, 01:22 PM Thread Starter
Quoted: 8 Post(s)
can I run the trans go kit with the john wood valve body?
post #5 of 6 Old 06-19-2014, 01:45 PM
Quoted: 289 Post(s)
the trans go kit mods the valve body but probably not as good as john wood does. maybe you can just use the pump mod that comes in the kit?
hopefully someone else will chime in
post #6 of 6 Old 06-19-2014, 05:57 PM Thread Starter
Quoted: 8 Post(s)
I see you have the tugger kit in yours, hows it go?
