tons of slap in the shifter - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-15-2014, 09:22 AM Thread Starter
PowerSTOKED_Bryan's Avatar
hey guys how are ya? the other night while backing in my heavy duty aluminum mowing trailer I noticed I have a serious amount of play in my shifter. its difficult to figure out what gear I have put it in because the gear indicator goes between say "P" and "R", or "D" and "2". I don't think its the cable to the transmission but perhaps the linkage on the back side of the shifter? anyone else have this issue?
2000 Ext. Cab F-250 Lariat(TOTALED)
2001 Reg Cab F-350 (mine)
AFE Intake
No Limit Tuning
4" straight pipe
2005 Harley Davidson Headlights
Early 99 Reg Cab (hers)
Tymar
Edge Evolution (temporary)
5" straight pipe
PowerSTOKED_Bryan is offline
post #2 of 8 Old 06-15-2014, 09:41 AM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Look up under the dash, above the brake pedal, and you'll see where the shift tube has an "L" at the bottom where the cable (that goes to the trans) is attached. That bracket is attached to the tube is attached to it with 2-Torx screws. Those screws become loose all the time.
Retighten them and it might be all you need to do
NoRalPh is offline
post #3 of 8 Old 06-15-2014, 09:44 AM Thread Starter
Awesome! I'll check it out. Thanks!
AFE Intake
No Limit Tuning
4" straight pipe
Tymar
5" straight pipe
post #4 of 8 Old 06-21-2014, 07:36 PM
Did you ever figure out what was wrong? I'm having the same issue. Some people told me that it was just the neutral safety switch because sometimes the truck will not start in park.
Just curious.
thanks adam
e99 7.3 Crew Cab 4x4
6.0 Trans Cooler
06 Mirrors (wired all but heat) 06 step bars
36" Tires/factory 06 18" rims
PHP Chip/Glow Shift Gauges
Crank Case Vent Mod
600k miles and still running strong.
AdamCap is offline
post #5 of 8 Old 06-21-2014, 08:54 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 328 Post(s)
Just curious.
thanks adam
Read NoRalph's post. That's the cure. I've had people come to me having already replaced the switch and the loose torx screws were the problem.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #6 of 8 Old 06-21-2014, 09:05 PM
BryceB's Avatar
One fell out while my wife was driving the truck. She didn't know what it was but found it laying on the floor. A few days later, I couldn't shift out of park.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #7 of 8 Old 06-23-2014, 05:47 PM Thread Starter
i tried looking at it when It was pretty dark out. I couldn't really see what the heck was going on under the dash...so I haven't resolved the issue yet.
AFE Intake
No Limit Tuning
4" straight pipe
Tymar
5" straight pipe
post #8 of 8 Old 06-24-2014, 12:54 PM
Solid98's Avatar
Quoted: 8 Post(s)
This video will give you a good idea what is going on under there.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
