Please help! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-13-2014, 02:04 PM Thread Starter
02GrantsGarage's Avatar
Please help!
99 f350 4x4
just put new flexplate/torque converter in the truck went to crank it and drove around the block did fine,
went inside to grab somthing to eat and came back out to move the truck cranked it up and put it in gear and nothing the truck would not move in any gear or any range of the transfer case...acts like its just slipping
i though maybe fluid but its full then i went to do a flush and when i unhooked the cooler lines nothing comes out even with the engine on....
does that mean the pump went bad?
2004, 2wd, EGR delete, headstuds, main studs, bluespring, cold air intake, sct tuned
02GrantsGarage is offline
post #2 of 2 Old 06-13-2014, 07:37 PM
heykw's Avatar
I don't think it pumps fluid threw the cooler until it's up to temp.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
