2000 Ford F450 throwing transmission code p1754 help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-08-2014, 05:49 AM Thread Starter
2000 f450 mason dump is throwing transmission code p1754 coast clutch solenoid cirtcuit fault. Anybody ever deal with this issue if so how did you fix the problem. told it could be a short or bad connection at the harness on the transmission. tranny runs shifts fine no issues except the o/d light flashing once you hit 4th gear and throwing this code.
any help appreciated
ziob is offline
post #2 of 4 Old 08-28-2014, 05:01 AM Thread Starter
bump to the top
ziob is offline
post #3 of 4 Old 10-31-2014, 04:21 AM Thread Starter
told probably just bad solenoid back sticking. Has anyone ever swapped these out looks fairly simple just want to make sure when you pop it off there isn't any check valves or anything behind it that will fall out and create a nightmare.
ziob is offline
post #4 of 4 Old 10-31-2014, 06:05 AM
timmyboy76's Avatar
ziob, best advise i can throwout is to google 7.3 p1754. You'll find quit a few threads...good luck
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
