auto to manual swap question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-03-2014, 08:16 PM Thread Starter
SUPERDUALLY350's Avatar
was wondering if there is any one out there doing a manual swap and how much it would cost.
SUPERDUALLY350 is offline
post #2 of 6 Old 06-03-2014, 09:28 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Cost would be anywhere from just the cost of a new clutch, to $5-6000
Best way to do it, find a rotted out parts truck, take what you need then sell the rest. I made money on my swap, including buying the new clutch
Otherwise you need:
Transmission
Tcase ( or new input shaft swapped )
Clutch pedal
Hydraulics
Clutch
Clutch fork because you want the updated one from Ford
Driveshafts, or get yours modified, if your lifted you may get away with the rear shaft.
Wiring will depend on what year your truck is
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 6 Old 06-15-2014, 06:04 PM
99bft's Avatar
Whats wrong with your auto?
99.5 F350 CREW CAB DUALLY 4X4, 4:10 (LS),ZF6 SWAPPED, RANCHO 2.5"LIFT, 305/70/16 NITTOS, RHINO LINED, B&W TURN OVER, TEKONSHA PRODIGY P3, MBRP 4" TURBO BACK, K&N CAI, PHP Hydra, Riffraff AIH DELETE, BILLET COMPRESSOR WHEEL, HPX,& "OCR", NON EBPV PEDESTAL, HIGH FLOW EXHAUST HOUSING, FOIL DELETE, ZOODAD, ISSPRO EV2 GAUGES, 6.0 TRANNY COOLER, EXTRA QUART POLISHED DIFF COVER, WARN HUBS, ARROWCRAFT SPACERS, ALPINE TOUCH SCREEN
OTHER TOYS:
65 N600 390
67 N1000 220 CUMMINS
99bft is offline
post #4 of 6 Old 06-17-2014, 06:58 PM Thread Starter
well i would like a manual and its starting to go mine has turbo goodies intake exhaust and a chip it just dont seem to handle the added hp and torque very well
post #5 of 6 Old 06-17-2014, 07:13 PM
BrodieBiking's Avatar
If you have a 99-01 its a simple swap, if you have an 02-03 there is quite a bit of wiring to do.
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #6 of 6 Old 06-19-2014, 06:10 PM
99bft's Avatar
i agree it is easy on a 99-01. Its even easier if you have a complete donor truck. just make sure its something that your going to love (im sure ill catch an ear full for saying this) because i wish would have never swapped mine I got rid of a perfectly good auto for this swap. The only time i like it is when i have it loaded heavy but my auto did just as good loaded heavy too. i could have had a stage 1 jasper with triple disc convertor with 3yr/100k mile warranty for less than i have in my swap. i have no warranty what so ever except for what little i have on the southbend. just my
OTHER TOYS:
65 N600 390
99bft is offline
